- Mar 1, 2017
- Manual
Hey everyone,
Brand new member. I have a problem with my 90 ranger with 2.9l. There seems to either be a short in the ground from the eec(pcm?) or the eec is bad. I can get the the fuel pump to run from jumping the neg terminal from the battery to a bare spot on the ground wire coming from the eec. The engine will run if I spray starting fuel into the throttle body until the starting fuel is gone. But if I keep the fuel pump running via the jumper while cranking the engine doesn't run. I am wanting to check to make sure the ground wire is good but I don't know were the eec is located and which pin is the ground going to the fuel pump relay. Good advice is appreciated. Thank you
