4.0L SOHC you wont believe it
thunderuncle244
Forum Member
Jacksonville
FL - USA
Other
the creeper for when my truck breaks down
Vehicle
Drive
if it aint broke break it
Check engine light came on on the way to get something for the truck. Checked the code small evap leak trased it and the evap puge valve had a little stain under it and I could blow through it so I'm buying I new one. I will say if it works.
You're right, I don't believe it!
Sounds like the voice of a man who doesn't want to believe it, but deep down knows it to be true. It's ok. I won't tell anyone.
No check engine light yet, though I could blow through the new one. I think the evap purge valve test where you blow through it is not for the ones that opperate off engine vaccum and have the diaphram.
the old one was still good looking back I had to blow really hard to make pressure go through it and the evap system does not have a lot of pressure hope this helps someone
the horn broke looks like a bad clock spring
I don't believe it...
and the cig lighter got sucked into the dashboard runnin rough as ever coolant leak oil leak mint condition
hehe
  • you wont believe it
