96RangerRed
Hi guys, ive been slowly rebuilding my 96 Ford Ranger 4.0L OHV and the last thing is exhaust. however a new fault popped up on my OBDII reader and it says "PCM Fail" not sure what happened but it just showed up a few days ago. now a bit of information for you here, I have Installed a slightly bigger camshaft (not oversized) its got a cold air intake, dual valve springs, and a BBK 62mm Throttle body on refurbished engine with about 3,200 miles on it. it has no exhaust system really so no O2 Sensors and im not sure if that's causing my issue or not but have a massive power loss and bad fuel mileage (for a Ranger). also my blinkers stopped working after I put LED Headlights in... and every once in blue moon my check gauge light flashes once and does not come back on and i get the same codes on my reader for O2 sensors and the PCM fail. also my throttle gets stuck open for a while when I shift gears, I have to pull the pedal back with my toe.( and yes I have cleaned my throttle body several times and no change I also made sure all my vaccum lines were attatched correctly.) thank you!
