pblaster help
Brandon
where do i get this product?
farm fleet, wal-mart, the parts store..... have you been unable to find it?
I've seen it at Home Depot.
pblaster
never herd of it before,could really use it out here in canada,is it an automotive product
It is a penetrating oil. I got mine at Tractor Supply Co.
Rust Bomb and Kroil are also good brands to look fore.
pblaster
this will come in handy,just bought a 3' body lift and was wondering if you guys could give me some help.fist the body mounts under the rad and doors are shot have new ones to put in.the body mounts under the rad i can get wrenches on both ends but is there a top side of the botls on the ones under the door and the rear cab corners and if so where are they located,or do i have to take the whole bracket off?
take the kick panels off, and panels along the floor in the rear, pull the carpet up a little untill you see plastic covers that pop off with a screw driver, the top of the bolt will be right there. the front are about in line with middle of seat, and the rear, if extended cab, is pretty much the very corner of the cab.
also if your going to do all this work, i would replace all the body mount bushings, even if they dont look badly worn they probobly are pretty beat if there original. mine didnt seem bad but in replacing them i noticed a tighter feeling in the truck when cornering.
one more thing, spray the penetrating oil for a few days at least, a week if you can before getting at the bolts with a wrench, they suck. bad.
pblaster
thanks for the info.
PBlaster + Kroil + Time = Miracle Max Miracles
pbblaster is without a doubt the best penetrating oil ever.and for all those people who use wd40.the only thing wd40 is good for is stopping squeks and thats about it
Actually WD-40 was intended to displace water, not even as a lubricant.
wow pretty kool.. makes my point even better-people try to use it as a lube and as a penetrater when its not for those puropses
kool
