- Aug 7, 2007
- Michigan
- My credo
- If you're not making mistakes, you're not learning.
SEE POST #15
Edit: 4.56 gears in an explorer 8.8 if your curious.
So I measured everything super carefully, except when I did the carrier shims. I re-used the old large shims from the original gear set, and just stuck a bunch of shims on the right side until it tightened up. backlash was .03 or .04 something I quit reading the gauge at that point.
Took all those shims out and stuck them on the other side, .010 backlash. Hot darn I'm in spec! so I did a pattern test.
Personally I think the pinion is a little deep, but I only put .028" worth of shims in it (pinion was marked -2, Ford racing gear set).
I also think there's a lot more tooth contact than I see in other gear sets. I'm not sure what to do about that, if it's even a problem.
I'm a little uneasy that I got it this close my first time through just jamming shims in it to take up slack lol
**edit edit** - I'm going to take another .002 out of the pinion and see where things are. Did some more fiddling just for the hell of it and came to that conclusion.
*Ignore this post*
http://i129.photobucket.com/albums/...ger dashboard removal/Rear Axle/100_08671.jpg
http://i129.photobucket.com/albums/...ger dashboard removal/Rear Axle/100_08661.jpg
*Ignore this post*
