Ive been having an issue where at about 1600-1800RPM and the middle third of throttle position, Im having a hesitation problem. The first third is fine and if you put your foot into it, it clears up. Also above 2k, there is no problem, even in the middle third.
Ive changed the TPS, swapped MAF sensors, changed the plugs and plus wires, and even the ECU, the CLT and IAT are both new, checked for vacuum leaks. I dont think it has anything to do with the SOHC because it ran fine for a couple months, then I let it sit for a month, fired it up, and its done this ever since. Its really annoying having this thing almost crap on you leaving a stop light. Ive been racking myself over this for a couple months.
Anybody had this issue on their EEC-IV 4.0's???
