SimplyTheBess
Hi all.
Got a 98 Ranger. I've noticed that when it is really cold my parking brake warning light doesn't want to turn off unless I screw with it for about 30 seconds. When its slightly warmer (say 45 or higher) I don't tend to have this problem.
I'll check the brake fluid level but I really doubt it is that as I mentioned I can get the light to turn off by simply set and dislodging the brake a few times.
I'm thinking more that the sensor for the parking brake simply needs to be adjusted by an 1/8" or so.
I've searched on the forums but looks like most people with this problem actually had problems with their brakes while I do not. Thanks in advance.
(By the way, if you think the cable just needs to be adjusted if you could show me where that is located at, that would be great!)
