Parking Brake Gauge Light
SawyerRanger
Southeastern MA
The "BRAKE" light on the dash does not go on when I put the parking brake on. Very rarely will it go on, but then it doesn't happen for a while. I know the light is working in the dash, because when i put the key in the "ON" position, the light illuminates. The brake works well, takes a decent amount of gas to get it moving when I've got the pedal depressed, so I assume it's not the brake.
Thanks for any help guys, it's an auto so it's really not as important as having the e-brake on for a manual, however on the few occasions where I feel like it's needed, I end up driving away cause I forgot the brake is on, and then I think I've destroyed my truck until I realize the brake is on. So the dash light would be awesome to have again
Also check the fluid level in the master cylinder...unless you have a separate parking brake light...mine comes on for both and if the fluid is low it will come on...
Don't mean to bring a dead thread back to life, but I fixed the problem and I figured I should post what I did since I couldn't find any info on this issue.
So I finally decided to fix it, and I looked under, found the switch, and unscrewed it, took it out, and cleaned off the flat contact plate, it was coated in dust and grime. Put it back in, and the "BRAKE!" light comes on every time I hit the E-brake. The switch looks like this, for those who don't know:
getimage.php
Basically the E-brake, when depressed, lifts off the switch, which raises the contact plate and makes contact with the teeth and walah, you have your brake light.
Ok, sorry to bring up an older thread, but my switch in my 1991 explorer busted, and i cannot for the life of me remember how it goes back in under the dash. Does anyone here have a good picture that i can look at?
