panel bulbs!!!!!
Brett06
Alabama
ok i went to the junkyard today and yanked a a/c panel face off another ranger, i got it home and planned on turning the little icons blue instead of green. I got one out of a junk ranger because i like having an extra to play with instead of using the perfectly good one incase i break it. Any way, i got the clear plastic all pai nted up and pulled the panel out of my truck for the swap, i popped the face off mine only to see the plastic was factory blue.... not green. So i started thinkin about it, my panel bulbs arent white, they put out a yellow glow, therefore turning the blue into green. what can i do to get a brighter whiter light and not a weird yellow color? any help is appreciated thanxx:icon_confused:
you can go to superbrightleds.com they have twist in bulbs that should fit. Other than that I am not sure where to find one that will fit the socket
superbrightleds.com i got the wledx5 something of that nature, it took 8 to do my dash, hvac, and turn signals.
Is there any difference in the climate control bulbs and the cluster bulbs? I am planning on getting an explorer gauge cluster next weekend so i am getting the lights for that. Im not sure how many are in there or what kind they are so any help from ppl that have done this would be great haha.
ok i must have missed this before but i found the article in the tech library, i found some led's that will do what i need. thx for the help!
the instrument cluster takes six of these:
http://www.superbrightleds.com/cgi-...ction=DispPage&Page2Disp=/specs/WLED-xHP5.htm
The a/c lights are different. and the cruise control lights are different from both of those along with the light that is behind my headlight switch. I am currently in the process of finding bulbs for all of my lights to replace the led's I put in a few years ago. So far I have the instrument cluster done and I am still ordering bulbs to find which ones fit. Many of them look similar but there are very subtle differences
if you havent seen it already in the tech section theres the thing i found, its about cluster removal but it has a spot about the lights and which ones you need and where to get them
