Broosedamoose
DaMoose is lose!
- Mar 10, 2012
- 4.0 V6
- Automatic
- Tire Size
- 31 x 10.5
- My credo
- Coming in second just makes you the first loser!
So I had the fluid in my transmission changed along with the filter and swapped to a pan with a drain plug. I used Wix products. Always had good luck with them. About a month later I noticed fluid was leaking from the pan gasket. I took it back in and they changed it under warranty although I had to pay for the new fluid. Well here we are are couple months later and it's leaking again! It's leaking from all around the pan and not in just one spot. I don't think I'm gonig to go with the Wix gasket this time. My mechanic seems to think it's the material it's made of. What do y'all recommend for a gasket and what material is best. The Wix gasket is a rubber material.
