C-Bear
- May 2, 2012
- Automatic
Hey y'all, I'm about to throw a grenade at my pickup with this problem I'm having, hoping maybe someone can steer my in the right direction with this P1000 code. Yes, I've used the search bar, let me break it down.
I got a '98 Ranger 3.0, 2WD, manual.
It had been running and driving great on up until last Friday. I started it up drove home about 15 minutes, shut her down, come back out about 4 hours later, and nothing, wont turn over, can hear everything engaging, lights turn on bright, radio works, dash lights are on yada yada yada. But literally nothing, its as if I was trying to start an automatic in drive. Tried jumping it and nothing.
I plugged in the scanner and got the code P1000 code for OBD systems readiness test not complete. Along with that on my scanner it shows that the catalyst monitoring, evaporative system, oxygen sensor, oxygen sensor heat and EGR system monitoring are all incomplete.
Now I've read up that the only way to clear a P1000 is to do a drive cycle, which I cant because I cannot get the stupid thing to start.
My question is, what am I missing? It doesn't seem that from what I've read a P1000 code would keep my pickup from starting. Since I've had the truck I've replaced the EGR, DPFE sensor and the catalytic converter was replaced right before I bought it, other than that the truck runs and drives great with the exception of the clutch starting to go out.
Where should I start? I know my way around a motor, just one that doesn't have all these computers in it.
Thanks in advanced, the sooner I get this thing fixed the sooner I can quit driving the 'ol 302 around.
