99 Ivan
- Nov 22, 2015
- Automatic
Hi, I have a 99 B4000 (Ranger) 4.0, 177K that is throwing the apparently famous P0401 code. I have checked all the vacuum lines for breaks and cleaned them out with Mass Air Cleaner spray. I know most are not fans of just replacing stuff but I don't have a vacuum pump but from what I have read the DPFE is the common replacement.
Before I take the throttle body off and look for carbon build up I figured I'd try to replace the DPFE for 20 bucks. I have the original metal one, any thoughts on aftermarkets for 20 bucks vs the OEM for 60 or 70?
I can physically blow into the ERG and hear it engage, I assume its ok.. I know, assume.. if I were to remove the EGR, can I clean it or is it just a swap?
Yes, I have read just about all the old posts, and thank you very much in advance! Ivan
