James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
- Aug 31, 2021
- Roanoke VA
- 1997 and 1999
- 4.0 V6
- Automatic
- Tire Size
- 31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
- My credo
- The perfect is the enemy of the good.
Here's a weird thing. This has happened twice and I want to know if anyone else has experienced this with the older PATS systems. Mine is 1999 so that was, I think, the first year it came out.
This is what happened. I was in a rush, stuck the key in and turned it quick with no wait. Truck acted like dead battery, kind of groaned, wouldn't turn over. I was like, great, and I don't have my jumpers with me. So I open the hood, wiggle the battery connections, they are tight, clean, ok, could be bad ground, whatever. So I try it again, and, no problem, it starts right up with strong cranking per usual. Then yesterday I did the same thing - late, in a big rush, same issue. I wait a couple minutes, and it starts up just fine. I think it is because the PATS computer is not new tech, in fact the guy who made my extra keys said they were 'balky' - they work, just not fast.
So what I do now is stick the key in, give it a few seconds - the "THEFT" light doesn't have to be off, or you can wait for it to go off, but as long as it has just a bit of time in between putting the key in and turning it, there's no issue. I have no idiot lights at all, and the charge gauge is always just about in the middle when running, so I would tend to not suspect the battery or alternator or any of that stuff. I think the problem, if there is one, is with me, not the truck. Just can't be in too much of a rush. It needs maybe 2-3 seconds to recognize that it's not in fact a theft. And if I do that, so far, it never happens, and I get strong cranking, immediate firing, etc. So I just wondered if anyone else ever experienced that. I think it is normal and the answer is just give it that extra couple of seconds and all should be fine.
