spakack
- Nov 5, 2007
- Automatic
Lets start from the beginning. My truck started acting sluggish and at a stoplight would idle very ruff. I changed the plugs and it seemed to do the trick. It would do it intermittently for a while. But then it just ran poorly all the time. Finally the check engine light came on and the code was a misfire on cylinder 6. I then replaced the Wires and coil pack based on what I could drum up from the Internet. My friend who helps me with all my automotive help tries to make sure none of the injectors wires are unplugged or compromised. I then picked up a compression tester and checked the engine and on the opposite side the pressure was all very close and normal. On the cylinder 6 side the other two cylinders besides the number 6 was lower. But all were lower that the other side. I replaced the head gasket all around and that did nothing. It still runs ruff but no check engine light has come on. I'm guessing because the power to the computer was cut.
I kept reading the net hoping that a known problem existed. I kept reading about heads getting replaced because the valve would get messed up. I thought it was worth a shot so I got some new heads and replaced them both and nothing changed. I'm almost at the point where with a few new parts I will have a new engine. I'm turning to you guys for help. I really don't care if my problem ends up being a $2 part I just want my truck back..
