P0303, p0000
Fraser1989
Hey guys,
I am working on my truck and am starting to research what I need to in order to fix the misfiring. I have P0303 and 4 codes of P0000. So I have a misfire in cyl 3 and random misfire.
I have read up on the probable causes and they seem to be plugs, coils, a valve sticking or a cracked head.
The truck only seems to misfire while at idle so I am assuming it is most probable that it is a spark issue? It is a 4.0 OHV with 260xxx KM on it. What do you guys think is most likely the cause?
It drives really smooth and gets good gas mileage on the highway. I have average 19 mpg with the instant MPG on the scangauge going to 23mpg. So I am assuming that it is not likely the head but what do I really know anyways.
I have ran 2 cans of sea foam through the gas tank and 1/4th of a bottle in the engine oil for about 200km then changed the oil.
I run injector cleaner and gas line anti freeze every fill up too.
Do plugs and wires, coil pack if it is really old too.
Postin' from teh Galaxy
Ordered Plugs and wires.
Ill let you know how it goes.
Usually a set of plugs/wires will do it, I was running my 4.0 on four cylinders due to two bad wires :icon_thumby: but it seems odd that it only does so on idle... when I would hit highway speeds and my crappy AT would put it in overdrive, my truck would violently thrash due to the misfires. It also sounded like a cammed-out v8 at idle :icon_rofl: I'm hoping thats all you'll need to do, but it doesn't make sense that it "stops" misfiring after idle, at least to me
