Oxygen Sensor, Bad Symptoms?
Run the codes, that might tell you if you have a bad o2 sensor
^ That.
Also, if it bogs down while holding a steady speed (like 55mph) and then goes back to normal it could be bad. You can try driving it with the connector off of the o2 sensor to see if it changes things too.
O2 sensor isn't an ignition component. It is electronic engine control.
