Bruce
I have a1994 Explorer that seems to want to overheat at times so here it goes. Driving down the highway at sustained speeds any where from 60 to 85 temperature is fine but if i stand on it to pass or if im pulling a an uphill grade hard like 6 -10 % grade or more where you have to stand on it pretty hard the engine temp will go way up( driving it with scanner on it will show about 240) but once you level out it will fall back to normal 195 temp. Here's what i have changed in it Radiator(which is 4 core),clutch fan, thermostat 4 times, and radiator cap.
Thanks in advance.
Thanks in advance.
