burtonkid87
- May 12, 2016
- Automatic
I have a 3.0 V6 ford ranger it's a 1999. In the past two weeks I had the cooling system flushed. I had a thermostat put on twice cause of the issue of overheating and the heat not working till given gas. After that I drove it to Michigan from Pennsylvania with no issue on the drive. I let the truck sit for 2 days at a friends. I started it she idle very rough for a few minutes I drove it up the street it overheated. I burped the truck and top it off with water she ran fine till I go to Toledo and it overheated when I was getting gas. So I repeated filling it with water as long as I stayed in the highway and driving she would not hear up till I hit places where it would have to idle. I got home and tried to get any air pockets out of her I placed the front end on uphill slant to get it to burp and the coolant lines. She drove fine for a few days then the same issue of overheating. I took it to Firestone and they couldn't figure it out they did a pressure test and they were left stumped and did not charge me as they said either water pump or airpockets which could cause rough idle. Though I have to put coolant into the system every couple days but no apparent coolant leak. I checked the oil to make sure there was no leaking into the oil. Which there isn't. No white smoke either. So anyone ever have a weird issue like this. I can drive the truck around fine as long as I make sure the coolants top off. All day no problems no overheating and got heat...so hellllp!?
