Skyman24
- Jan 27, 2015
- Automatic
My truck is overheating and I don't have heat at all. My heater core makes an exhausting or bubbling sound (idk how to describe it) if i move the selector from defrost to vents vise versa. I have no heat at all extremely cold air blows out. My vents don't blow air either only defrost does. My cab has been been very moist and my wind shield has had water on it from inside the cab, but i dont have any major leaks or anything and that was the case before losing my heat, just figured i'd be as descriptive as possible. The lines going into the core are both cold. The heater control valve does have vaccum and is being actuated. So thats the symptoms on that, I'm more worried about the overheating than the heat in the cab though. As far as the overheating when i drive the temp is ok till it reaches operating temp and if i drive it for a min or 2 past reaching that or once i hit the highway the temp gauge pegs out to red and stays there. It has come back down 3/4 or 1/2 after driving for a few miles or slowing down but not often. I'm boiling coolant in the upper radiator hose. I just put a new radiator in the truck because the old one had a leak. After the job was complete I notice I was overheating and boiling coolant. So I pulled the thermostate out to make sure it wasn't causing problems. I am leaking a slight bit around the termostate housing now and i still havent put a new thermostate or gasket on yet because it wasnt the problem and i figure the more flow the better right now. when attempting to bleed system of air, once the engine reaches operating temp with no radiator cap on the coolant pukes out and then I fill it back up only to have it puke right back out. Before it reaches operating temp the coolant seems to steadily trickle out. The upper radiator hose is warm before boiling and the lower radiator hose is cool. The water pump was replaced a couple years ago but I'm not ruling it out. It may have a leak and I had water in the system with no antifreeze for a while because of leaks I had at certain times so when my radiator cracked when it was below freezing weather the impeller may have broken but I don't know. I do know that I remove the intake to change the gaskets out and there was brown crap in the two ports front and back of the motor that I cleaned out as well as possible. So yeah I have not been nice to the cooling system but I ran some flush through the system this past week to help and drained that out and put antifreeze in it but no luck still over heating. Also the coolant over fill is not bubbling either. So idk if it is a head gasket. I was gonna try flushing it with a hose next but I'm not sure where to put the tee at. It says on the inlet heater hose but idk which one that would be since they seem to run together. I could go before the valves and stuff but I'm not sure if that's what I should do. If anyone can help me please let me know. As of now I either think I have a blockage, my pump is bad, or I have some air trapped. If your have a product I can use to break extreme blockage or a way to be sure there isn't trapped air let me know. Oh yeah my radiator cap is new too. And i never put any gasket or radiator repair junk in it. And I have a 98 ranger 4.0 v6 2wd in case you needed to know.
