here are my installed pictures.....hardest part is cutting the headliner and making the slots in the roof support of the cab for the front console clips to go into....other than that it is cake to wire up..
any '95-'01 Explorer OHC (Over Head Console) will work easily as long as it isn't the one that has the sun roof button on it....the sun roof button ones are harder to install since the rear portion is supported by the headliner, not the bracket...
this is Ford's calibration instructions for the temp portion:
hold down the "MODE" button for about 3-5 seconds till it comes up with a single number, then find which zone you are in from the picture below and push the "MODE" button till that number appears....then let it switch back to normal (it will do it automatically after setting for a couple seconds)....
here is a GREAT how to that 99.9% of members of
www.ranger-forums.com follow to install their OHC's...
This is the Install portion:
http://www.cardomain.com/ride/296394/3
This is the wiring portion:
http://www.cardomain.com/ride/296394/4
if you search around that Car Domain site, you will see that there is numerous other GREAT mods like the EATC, all auto power windows, and LED light installs....
