- Aug 7, 2007
- Michigan
- My credo
- If you're not making mistakes, you're not learning.
Kind of a specific to me post, but overall towing with a manual in overdrive info is appreciated. Warning - I'm expecting relatively in depth responses, you know, with reasons and all that.
So I could have sworn there was a wealth of into about towing with manuals and overdrives, maybe that was on the old forums? I searched here and in the transmission forum and couldn't find anything. Also tried plain old Google but all I got was automatic tranny related nonsense.
So a few of the topics in the "other engine swaps" forum have got me thinking yet again on a diesel swap. I researched a ton many, many months ago and decided against it. Now some recent curiosity and newer sources have peaked my interest again.
**Some background info: Actual questions are under the yellow text further down**
This swap would be the more economical one, a 1.9L VW TDI - likely chipped, no other mods - 02/03 and older. Quiet exhaust system (fairly low restriction though), driven responsibly, if anything hopefully easier to pay off by running on biodiesel (including paying taxes and being legal about it which should still be less than $1 a gallon). Chip is rated at 116HP and 195lb/ft of torque. Not exactly stellar, but I'm used to cruising around with the 2.3L so it's quite an increase in torque. I expect a bit of a learning curve with the new torque range (pun?)
Because I was amassing parts for a 4wd swap in the process I'm hesitant to change the overall plan. 2.3L/3.0L M5OD ratios / 4.10 gears / 31" tires. I'm willing to bet the M5OD will hold the torque, also It won't be jammed up against stumps and rocks, I have a built Ranger for wheeling. This Ranger is basically getting 4wd for low-range while backing up and other slow speed maneuvers, and because getting stuck in driveways/parking lots and the ever awesome traffic signal get's old quick. So... this would put me @ (roughly) 2150 RPM @ 60mph - 1970 RPM @ 55 MPH. I know the engine will be okay with this as this is at it's peak torque range and probably a little higher than the actual peak torque RPM, but these numbers are in OD - 4th would be 2720 / 2490 RPM @ comparable speed, which is a little high. It never bothered me before because I'd just leave it in 4th and let it rev a little.
I don't want to kill my new found torque through gearing up, nor then have my overdrive RPMs be ultra low. So depending on the feed back I receive I'm willing to re-do the gear ratios, and/or find a different transmission - though I'd really prefer not to.
I've towed a ton with my Ranger before, more than most ever should (and what many think the 2.3L ever could) so I feel I know my limits. Which happens to be about 4,500lbs or so. - this is the heaviest load the Ranger would be carrying for any moderate distance. Fancy trailer setup, brakes, controller, the whole 9 yards.
I'm confident the bulk of the M5OD will handle the torque (1st-4th), and the OD empty will take it. But I've never actually used 5th gear (OD) while towing anything. There really is no super science to my proposed gear/drivetrain combinations, basically stock equivalent from what I have now, just no letting the engine rev.
SO - what I'm wondering:
How will OD deal with a load for long periods of Interstate?
Are they're any other issues associated with the M5OD's 5th gear aside from a shifter issue? (not going into fifth, seen that one a bunch)
To those who have been around the insides of a M5OD, do you feel the 5th gear is well supported (bearing wise)?
Should I look into a heavy duty bearing retainer plate? (I've looked into T5's - and that is an issue with them) I haven't been into a M5OD yet.
The M5OD-R1/HD is supposedly stronger. Since I need 4wd parts for the back of the tranny, should I seek out one of these and swap over 5th gear parts as well?
*This is a STD. cab, short bed Ranger, so the lightest of all the body styles.
*The Tranny/Gear/Tire combo is only suggested as that it is the equivalent to what I'm currently running - I.E. bone stock. (225/70?R14 - 3.73 ;factory / 31x10.50R15 - 4.10). It's not based on some crazy equation, I just ran the numbers and it appeared to work moderately well with what I have.
*I'm not seeking comment on my choise of gearing and weather or not it will work out, just the strength of the M5OD-R1's 5th. I supplied that as background information that it won't be facing "normal" power. *Don't worry about it Bubba Bob. Just figured I should clarify things for others I'm not actually pissed or anything lol.
*A few edits, maybe clear some things up as to the information i'm seeking.
