cbxer55
- Oct 9, 2009
- Automatic
All this talk about NE, NW, SE, SW is irrelevant anyways. There is only one question you need answer. When the engine is running, and you hold your hand anywhere behind the fan, do you feel a lot of air movement toward the firewall? If yes, then all is good. If no, then you got problems.
There is a way to check the temp gauge you have using a known temperature. Remove the sending unit from its location, but keep it hooked up to the gauge and power. You will have to run a ground wire from the sending unit back to the vehicle, some kind of jumper wire will work. Bring a pot of water to boiling, hence 212 degrees. Drop the sending unit in that and see what your gauge reads. If the gauge reads way north of 212, you will know you got a junk gauge, that is entirely possible. I had a oil temp. gauge on a motorcycle that always read what I thought was too hot. When I did the above-mentioned test, it showed 240 degrees in boiling water. So it was reading 28 degrees high.
The 230 to 240 degrees you are showing would be pretty good for oil temps., but not for your coolong system. Theoretically the temp. should not be much higher than whatever thermostat you are using.
