"outrangerous" wrapping up for this year, almost there
rjaaaaaa2
gettysburg, Pa.
So I pretty well finished the fiberglass rear rollpan today, test fit the panel. Seems to line up ok. Need to go behind and locate some new mounting brackets to bolt it up and glass them into the rear of the panel.. Cut out the two taillight openings and the slit for the led strip. I'll make up some mounting brackets behind to hold the taillight assemblies in place, run a bead of silicon around the back edge and let it dry to act as a gasket. I bought a 5/8" diameter clear plastic hose tha I will silicon in place in the long slit, then I can slid the led strip into it and it will then be replaceable without to much trouble.
I need to put it back together so I can use the truck during the spring and summer.
I think I will be able to bring the duel exhaust up the passengers side by crossing the left header pipe over just behind the bellhousing and bringing both back and putting the mufflers in front of the rear axle then splitting the left pipe off back over behind the rear axle, take it up and over around the spare tire well and out the rear. The right side well go up and over also and exit at the rear in the curve of the roll pan. I'm going to get some wide ovalish tailpipe tips.
