Our prerunner, Pic's & vid
00dangerranger
CA. Elderwood population 170
First time out since shock rebuild. Every thing performed like a top. I got this posted in RBVUC, also but no replys.
Did you build those coil buckets? Got anymore pics?
no They were on there, but this is what it looked like when i got it. All the seals were bad. I had 3dsandcars rebuild, revalve and rechrome the shafts.
Looks good, any future plans?
sick! needs more videos though... and maybe a big star on the doors of your truck...
edit: nevermind, i found more videos
yeah it has 18" racerunner swayaways in the rear with a deaver leaf pack.
I want to 4link the rear and order the coil set up thats made for those swayaways.
It never bottomed out but you know.I WANT MORE....
So just for referance on a 4.0l v6(Running Great) with a 8.8 posi,detroit locker,sierra gears & axels 4.56 ratio on a 15"x8" rim with a 29x11x15 paddle with 16- 1.5inch paddles per tire behind a stock 5speed tranny will pull max RPM in 3rd but only max out at 3300 to 3500 RPM in 4th gear, Full Chicken< Everything shes got Captain, Style.
Even though it don't pull compleatly through 4th I still wouldent have went with a higher gear ratio. just beacause i feel 1st through 3rd is perfect and would wind out way to quic
if i would of went higher. So if anything i wish i could shorten 4th. Thats my 2cents for the sand anyway.
oh and i believe the wind was blowing S SE at 30mph while i was traveling W. lol
may help for future gearing. Back paddles at 5psi front 33x12.50x15 at 7psi. 2wd
