what tool bit should I use to cross drill a hardened shaft?
1/16" hole, goes about 3/16" deep to hit the open center.
I was able to drill the top pocket easily, the sides just laugh at my standard bits. using Tap Magic and started with hi speed, no go.
this is the shaft for a 3.0 cam synchronizer. the plan is for an oil reservoir at the top filled with cloth or fiber and a cross hole to slowly release lube to the shaft. a hole in the center of the sync cap would allow easy access to add more oil.
yes, I know the hole is not centered, but it's within +/- .050 spec!!
