Other yoke options for bw1354
cyclegrip
I'm trying to use a 1330 for the front output where could I get one? Can I use the rear yoke on the front?
Sent from my Galaxy Nexus using Tapatalk
no one knows?
I think there's some un-clarity to your original post as it relates to your post title.
Most people don't like the bw1350 yoke and are asking how to change that to a 1354 fixed yoke.
Your post title indicates you want to change out your bw1354 yoke.
You ask about a 1330 yoke, which I guess is a misprint.
If you clear up for what you're asking I think we can help, it's just hard to tell exactly what you're asking.
The front output on the bw1354 isn't a 1330 ujoint and that's what size my bw1356 was front and rear and I'm going to be using those dshafts
Sent from my Galaxy Nexus using Tapatalk 2
I see, you were talking about ujoint size. My mistake, I'm not as well versed in the ujoint sizes...I'm not sure what it takes to upgrade a yoke. I was trying to do some sort of research on that myself for converting a bw1350 yoke, but netted little results.
Pull the nut off and change the yoke. Pretty simple little task. There are some old threads about it on here and several other forums. You could also just use an adapter ujoint.
I understand how to change it I don't want to use a 1310 as its a ranger on tons and 42's
Who cares? That isn't going to be the weak link. I happen to have 1 ton's and 39.5s myself. The drive shaft ujoint isn't the one that will let me down.
Which one will?
I know my Yukon super joints won't be the weak link
Also gonna use sch 40 for dshaft
Which one will?
You do know 1310s are stronger at an angle than 1330s right? That's why most people keep them and if they do upgrade they just to 1350s.
