Orange 1977 Pinto
Well, I'm almost ready to start working on it. Finally moved it to the lift. Need to get it running first before I lift it.
Orange 1977 Pinto
I've been dicking around for several weeks a few minutes at a time trying to get this to fire up. I think(hope) I've got it narrowed down to the control module. I ran across a thread where they use an HEI module in place e of the duraspark module. I went to the local parts store and bought one for C$55.00. For shits and giggles I asked about a duraspark module. I was floored (see what I did there...) when they dug one out for me! C$100.00... Not a bad price... But I stuck with the cheaper option because it doesn't need a resistor, and can use just about any coil including the tfi coil. I'll link the article I pulled the info from later.
So now I need to mount this thing. Dug around in my scrap aluminum pile for a piece big enough to work as a heat sink. Got that cut out and mounted the module with the provided thermal paste. While I was rooting around for screws I found a fan that I recently removed from some computer equipment. Mounted that too with screws I had kept years ago from some other computer and electronics dismantling I did. The ss screws had a metric 1.5 25 hex head. Happens that I have a kit bought at Radio Shack, again years ago, that has that exact size. That size makes about the same size hole as a sewing needle, which I figured out after jabbing myself with it.
I haven't figured out exactly how I'm mounting this to the fender yet, probably drill some holes thru and come from the wheel side with some self tappers. I'll let you know.
Got it to run by turning up the idle screw. It sounds like it's missing but I had a couple low cylinders psi. Hopefully the pressure comes back with a bit of running. Now to get the charging system back together, test the radiator and system, and clean the fuel lines and tank. The old fuel looks like thinned diesel oil... black!
There is want - just sayin' - and it has me.
the black goo.....is a headache.
