BroncoToby
Just finished fixing my ABS a few minutes ago...
So now that leaves me with two problems to go...
One: My cruise control does not work. I am guessing it it the VSS which I think is located next to the spedo cable. Can the sensor be cleaned, or is there something else more common than the VSS that could cause the problem?
Two: My tach reads 1500 at idle which I know is wrong as I measured it at about 700. At about 2500 it reads 4000 and at about 4000 it reads 4000-6000.
Sometimes it reads 0 and sometimes it reads 6000. Sometimes it does the robot.
Anyway, if there is an answer in the tech libraries I must have missed it...
Thanks,
BT
Thanks,
BT
