Only one speaker working
TheDish
I have a 2000 Ranger and recently I noticed I was only getting sound out of one speaker (passenger side) the interesting part is when I roll my window down a little I can get sound out of the driver side. It's an extended cab and I get no sound at all out of the back. It has power locks and windows (I'm also experiencing an issue with the driver side door switch able to lock the doors, but not unlock them, while the passenger side is able to lock and unlock both doors) Any suggestions on how I can remedy this problem? Thanks!
Try movin around the bundle of wires comin from the front into the door. My driver side speaker has a loose connection so I just move the rubber covering around until I hear it
yep something is grounding out. might wanna take that door apart and find it. probably a bare wire from rubbing up against the window assembly./
More than likely a broken wire.
