NPHLYT
I have a 2003 B2300 that is in need of new front struts and lower ball joints. Since I will have the suspension that far apart I will be replacing the struts, upper and lower ball joints, bearings, seals and brake pads (it is time for them anyway). I will also inspect other linkages while I am there.
My question is, where is the best place to get replacement parts online (not performance or lift)?
Does anyone know how tall the springs are so I can check then to see if they require replacement. There only looks to be an inch or inch and a half of space between the bump-stop and where it stops when at rest on level ground. I will take pictures if this will help. Is it worth it to just replace the springs while I am there? Anything else I should look at?
