kenwheeler
I'm not sure if I'm doing this correctly. Please check my procedure. I'm trying to remove a replacement 5 speed trans from an 87 2wd.
1. dropped the driveshaft
2. removed the wires
3. removed the starter
4. removed all but one mounting bolt from the trans to engine.
(the pass/side top middle bolt is tough to get to and hard to turn)
DOING TODAY
5. cut the line that goes into the front of the trans
(I'm guessing its the hard to remove hydralic clutch line)
6. trans jack under the tranny
7. remove interior shifter boot/shifter
8. drop the rear crossmember/transmission mount
9. transmission slides back and comes down
10. transmission goes into the garage
Am I going about this the right way?
DOING TODAY
