Doug Burgoyne
Hey folks, I'm replacing stock set up in my 1984 2.8 with points distributor from 1974 mustang II along with non feedback 2150 style carb. I had just put fresh factory recommended motorcraft spark plugs for original tfi ignition. Gap is .044. Looking at 74 mustang II specs for dwell, timing, etc., and it shows .034 for plugs (assuming due to less spark energy with points vs tfi). I'm running stock coil with 1.5 ohm ballast resistor in line from "run" wire to coil along with 12v "start" wire. Just ground wire from coil to condenser. I'd like to keep the new plugs, just pull them and regap to the .034 specs. Do you see any problem with this plan? If I have to, I'll replace them (already replacing brand new rotor, cap, and wires I just installed for tfi dist., since none work on points dist.) Thx!
