the first is the engineer that couldn't see the need for future service and placed the O2 sensor to where it obstructs about 1/8" of the space needed for a socket and extension on the upper exhaust manifold to Y pipe nut.
I'll call this person half-assed because they did do a decent job placing the lower nut.
it must of been one hell of an engineering demand that prevented rotating the exhaust bolt pattern or the O2 a couple degrees for a clear path.
the second praiseworthy design genius is making the O2 connector about .050" bigger than the hex surface thus preventing sliding a boxed end wrench over the wires for a better grip on the sensor.
here in the rust belt an open end wrench ain't gonna cut it, and there isn't room for the special socket. I have broken the offending tab off that connector before, just not ready to do it again.
dishonorable mention goes the guy that left just enough room to slide thru the wheel well and under the heater box to get a wrench on that upper nut, then putting a brake line in the middle of that opening so you can't swing the wrench enough.
Pulling a 2.3 out of a 2005.
after I get that top nut I can drop the exhaust system, then have plenty of room to get the O2. WITH A PIPE WRENCH
