- Dec 6, 2007
- Automatic
Blown, Lowered, Lightened, Aeroed, 2001 Edge Extended Cab
My goal was to increase handling and ride. I put on 255/70R15's
I cranked the front down. Out back, I cut down the overload leaves, removed the 2 1/2" blocks, and cut down the bottom leaf to lower the spring rate. I felt the need to reduced the spring rate as I removed weight. I was bouncing all over hell. I'll add that removing the heavy blocks and leaves lowered the unsprung weight which helps handling.
Weight reduction:
I removed the jump seats, spare tire holder/crank and section of frame cross member it was mounted too, removed the 2" towing hitch, tailgate and cut down the rear bumper.
I moved the spare tire up in the bed behind the cab to redistribute the weight to a better place. Note that everything I took off, accept the seats, was behind the rear wheels. Taking the weight off there helped handling considerably. There has got to be at least 100lbs removed back there which had leverage and was adding to the force trying to swing the rear end out when cornering.
Anything I miss or others have done?
I'd like to convert the front to coil overs eventually but think I will try a lower spring rate torsion bar first.
BEFORE:
AFTER:
Weight reduction:
BEFORE:
AFTER:
