- Feb 22, 2011
- Mississippi
- 3.0 V6
- Total Lift
- N/A
- Total Drop
- N/A
Well my 2.0L bit it last sunday. I had a loss of power that friday before, ithought it mght have been water in the fuel. Then i thought it might have been back pressure. Well to make a long story short i was driving her kind of hard and she popped and shut off and never started back up. I thought maybe it had jumped timing, no that was not the case. After find out that the distributor's gear retaining pin snaped i turned the distributor in for a waranty return and timed everything perfect and nothing. checked compression cylinder 3 had read only50 and the other 100 to 125. I am going to start the rebuild after my wedding this week. I am hoping I can just hone the cylinders and replace the rings but we will see. if the cylinder walls are too scared then i am going to bore it.
Which brings up the question where can i get just a bottom end rebuild kit?
