OK here we go again!
groovtubin
NC
2.9 V6
Went out to crank the Bronco II Key over, FUEL PUMP PRIME ...NO start...... Its cold, i dont have a garage, soon as it warms up, il TS the Ignition again, this XACT same thing happened over late summer, n i repaired a broke coil wire to Ignition module, what will it be this time? :) In last post i was ALMOST home it sputtered n went into limp mode..
OK Braved the harsh elements of nature, pulled off the IGN Module connector, SLAMMED that puppy home, Key over FUEL PUMP PRIME WE HAVE IGNITION! :)
OK, NO time to get into it heavy today ( no im not on a date) All i had time today to do was pull back carpet slightly and the WHITE BUTTON on INERTIA switch actually CLICKED when i pushed down, i hvnt checked for 12 volts at fuel relay, B4 this either.... Ive got RUN n COIL voltage at TPI connector, didnt get to CRANK voltage Also the OHMS is GOOD on COIL, i PULLED the secondary wire tab... used a test light, it LIT up cranking....., but couldnt tell if it was FLASHING...( pulled secondary tab OFF the coil n read that directly, maybe wrong?) anyhoo, ill try n crank tomorrow, gotta fuel press gauge for troubleshooting on way, did i say how MUCH i miss driving the Bronco II ?? Its my main ride man! :)
Installed SPARE TFI Module ( it wil miss @ 2500 RPM) but does ....................START............ Going to FordMOCO n get the REAL thing, Car parts n Advanced Zone are worthless...for TPI's imho.......................YMMV.............
FINALLY got warm weather n stuffed the MOTORCRAFT TFI module in HOLY SMOKES! It really feels like i gain 100 HP, it JUMPS N TAKES OFF NOW like a bulldog in heat!! $168.00 set back but WELL worth it. IT LOOKS to be a Delphi which is ruffly $20 less B4 taxes on evilbay, NO motorcraft insignia BUT they did throw it in a Motorcraft box, how lovely, FWIW IT ROCKS NOW! :) HIGHLY recommended over the AutoZone Oreilley, and Advance CHEAP counterpart..
