- Oct 9, 2009
- Automatic
Is your truck flex fuel? If it is, and you have access to e85, it's the best fuel system cleaner going for the money. If you decide to try it, just make sure that you phase it in slowly with partial mixes first. Going directly to 100% e85 can loosen up sludge in the fuel system too quickly that breaks loose and clogs injectors.
It's a 98, not sure there were flex fuel vehicles in 98. In any event, the fuel system cleaner I use is a combination of methanol, MEK, acetone and toluene. Pretty potent stuff, but it's only 15 ounces at a time. Been using it every couple tankfuls since forever, cause this truck has always had this problem in one shape or form. Sometimes bad, sometimes not.
My sister had no problems with it, from 2010 to late 2013. I had no problems with it from then until January, two weeks after putting in a new pump and filter.
I'm definitely going to remove the upper intake and get the injectors cleaned sometime this year. Maybe new ones, but at around $90.00 apiece, I'll try cleaning first.
