ok does this make any sense to you guys at all?
they had rangers but instead of having california models......they were texas models :icon_rofl:
lol
come on guys you shuld know ford made a black ranger then. lol here it is you might have a hard time fitting the 351 in there but some manhandling is required
someone call GWAII!!!
351w efi and 5L HO motors should almost swap straight across... the firing order is the same and should be interchangeable...
'runs' and 'runs well' are two different animals.
Yes, the M was a toned down 400, and the Cleveland was it's own awesome beast, but you and I both know that if the swap was that easy and involved adding two injector plugs to the 2.9 harness, its more than just a safe bet that the engine in question was a Windsor.
Also, the OP clearly states it was a 91 MY engine. The W was the only 351 still in production into the 90s.
And he might have a hard time just throwing that M or C block in there and plugging the ranger harness into from an EFI truck to a carb'd motor.
:icon_welder:
I also have a 1972 351 Cleveland its the cobra jet with a whole lot of goodies done to it but I don't know how well that would ever fit down in there I had it in a 1994 mustang so it has the right oil pan but as far as using the conversion headers and god knows what you would get into with the steering that could be a mess
You should go over to the V8 swap forum if you haven't. There's a few stickies that tell you what other people have done, what fits, what fits easily etc.
as far as headers go, if you're planning on stuffing a motor like that in, then just cut the inner fenders to fit the motor in and deal with the rest later...
as for steering, you could do one with several u joints, you should see the steering system we have on our FWD streamliner! i'll see if i can find some pics...
edit:
the "red" bar at the top of this pic is part of the steering, it's a little chared here, because this was taken right after the car lit on fire during a run
here's another one (too big to img) you can see the red steering on the side of the motor, right at the top
http://1.bp.blogspot.com/_30Z6BIQolRQ/SjYUmpkCEQI/AAAAAAAACOI/eEx3TaHJ7pE/s1600/goldenhawk+018.JPG
My buddy swears up and down that he took a 1897 ranger with a 2.9 in it and swaped a 1991 351 f.i. motor extended the wires to the injection for the other 2 cyl and pluged in the computer for the 351 and it all worked just fine there has to be more to it wouldent there be? :dunno:
depends if it was remote mount tfi or not..i have seen 91 models with both systems...the old school and later setups wiring wise...not caring if the knock sensor, power steering pressure switch, etc were functioning and assumes your using a non pcm controlled auto or a manual trans..especially if your were going to use the 351 early style pcm....the thermactor system and egr stuff can be an issue with the 87 but that is not part of most 88.
swap in the dizzy mount tfi distributor and it is basically "that simple"... though the tp wiring and egr stuff needs work too if keeping to that with an 87, the 88 ranger most dont have egr.. and using the 351 pcm is ideal but it will give error codes trying to use the 2.9 harness exclusively..
if your happy with stock power it works fine. but i have seen several issues with odd firing i never tracked down
Even with the dizzy-mount TFI, wouldn't you have to rearrange the ignition harness a bit? The 2.9 had the dizzy at the back, the small block's had them up front. I'd think the wires would need extended to reach.
gwaii, we need you to put the above motor in the above motor carrage...
if you leave the pcm in the truck you will on certain setups. depending on what setup the truck has depends on the extension or not. some have the room to fish it out of the loom and go forward. some 2.9 setups have harness connections that separate injectors etc at the valve cover and are a bit different. one 4.0 swap i did had the hybrid harness and made for some head scratching.
