93shortbox
- May 3, 2010
I am replacing the oil pump in my truck due to the knocking it was making. I found this in the tech section and would like more info on it. "Some 2.3L engines (especially 1992-1993) have knocking on the lower left side of the engine. The cause is oil pressure problems. The solution is a revised oil pump and a gallery plug with a pressure damping rod." I need more info about the gallery plug, does it come with the new oil pump? Where is it located? Where can a replacement be found? Any info regarding the gallery plug will help.
