96
- Sep 7, 2013
So my truck is running weird after doing a timing belt change. I've taken it to a shop after checking everything and the shop as well, they told me to pull my timing cover and check everything. I know the camshaft and crankshaft are dead nuts, cause if it wasn't it would run horrible. I know because I've done it more than once. So I read, the oil pump has to be aligned correctly because the camshaft sensor is mounted to it? The oil pump pulley is most likely off a tooth or something.
