Johnnyboiranger22
- Nov 1, 2017
- Age
- 29
- St Petersburg, FL
- 2.3 (4 Cylinder)
- Automatic
- Tire Size
- 215/75/14
So from my previous posts i was diagnosing a oil needle fluctuating problem, I ended up doing the pressure switch which is a dummy switch but that didn't help so i ended up doing the oil pump and my main reason for creating another post is a lot have been mentioning could be main rob bearings Honestly i didn't notice any abnormal noises that i know of and there is not metal shavings in oil anywhere and it looks pristine under there, my main concern is putting engine back together and it still doing the oil fluctuating,so my main question is should i do the main bearings? How often do they fail? Truck is 1991 ranger 130k miles 2.3L. I already bought main rob bearings and engine assembly lube.
