LearjetMinako
I'm trying to ask myself a few questions trying to figure out this oil leak. This is the third time I will going back in to fix this leak. Last time, I did a lot more (new water pump, timing belt, timing belt tensioner, and oil pump seal & o-rings). And I have already replaced the the front crank seal before. So what I'm trying to figure out is does the oil pump have a weep hole to indicate a failed bearing seal?
Also, one the forums members mentioned in other topic that there is a oil channel in the center of the shaft. And that when when re-installing the sprocket bolt, to make sure to use telfon tape on the sprocket bolt. Is this true?
