Broosedamoose
DaMoose is lose!
- Mar 10, 2012
- 4.0 V6
- Automatic
- Tire Size
- 31 x 10.5
- My credo
- Coming in second just makes you the first loser!
My mechanic said I have a small pin hole in my lower oil pan so I need to replace it. I'd like to replace the oil pump with a Melling high volume pump and a new pick-up tube/screen while he has the pan off but I'm getting some conflicting information about whether it can be done with the engine in the truck. It looks to me like the pan just drops off and the oil pump should be right there. Why is some information saying either the engine has to be jacked up or the front axle dropped? There isn't a problem with the pump. I just figured it would be a good time to replace it. The engine has about 100K miles. This is on my 07 4wd Ranger with the SOHC.
