oil pressure sending unit cant find
MadMike
Morinville
I have a 2010 FX4 4.0L V6 installing an oil pressure gauge but cant find were to hook up the hose any help would be great thanks:icon_confused:
itll be on the side of the block, not sure if driver or passenger on that truck, but ur gonna have to install a t fitting into the hole for the oil pressure gauge so ur stock gauge will remain functional aswell(compter controlled doesnt like seeing no oil pressure)
thanks but still cant find it ? what does it look like i have the tee fitting just need to find where to screw it in
I put a gauge on my 01 ranger 4x4 4liter sohc 2 weeks ago. Take your left front tire off and take off the rubber dust cover and you can see the sending unit just below the p/s pump. http://www.autozone.com/autozone/pa...filterByKeyWord=oil+pressure+sending+unit&fro this is what mine looked like. I had to make a tool to screw the tee in with because everything is in the way with the front differential and all . It was a bear. good luck
