Oil pick up tube 2.3, is '89 and '93 the same?
Fairlaniac
Denver, PA
3.0 V6
I want a pickup tube for my Ranger. I'm putting together another 2.3/M5OD combo while I'm still driving my Ranger. I found a '93 pickup tube locally. Will it fit my '89? Any leads on a cheap '89 type, 2.3 oil pan? Using a '93 'Stang 2.3 engine, void of any accessories.
Thanks,
Better yet, after wasting money; the Ranger and Mustang oil pickup tube are the same part. Hope someone benefits from this.
I know the turbo motors and DP (dual plug) ranger ones are different. However, when I built my turbo motor I was using a ranger block and oil pan (ranger pan is cast aluminum and much nicer) but I wanted to use the higher performance turbo motor pump which required the turbo pick up tube. All that was required was a little bending of the tube so that it wouldn't interfer with the pan.
