rancheroo
Hello all. New to the forum & have a Ranger question or two.
I bought a 1988 2.3, 2wd Ranger the other day. I knew it had an oil leak, but I'm mechanically inclined, so no biggie. I pressure washed the engine, above & below, and saw that oil is seeping out of the front of the pan gasket. I also noticed that my cast aluminum pan has F1nn (F1 number number) cast into it, so I know that it's at least a 1991 pan & couldn't have come in that truck. All of the other casting numbers that were obvious to me are E7nn or Ennn (designed or built in the 80's).
Question, did the 1988 2.3 have the cast aluminum pan & is the gasket the same for a 1988 and a 1991?
One other think, the trans (manual) DOES bolt into the back of the pan.
Thanks in advance, Rick
