Oil pan drain plug torque?
Look at the sealing flange on the drain plug and the pan bung hole next time you pull the plug. It might be that the plug seal is worn or something is up with the pan. This assuming re-torquing the plug didn't work and no other leak sources were found. Keeping the engine and bay clean goes a long way towards seeing issues before they become bad ones.
