Gnomad
- Jul 26, 2009
My daughter recently bought a project beater with a heater to save her Mustang from the ravages/dipshit drivers of winter, the subject vehicle is a 93 Ranger Extended cab 4x4. 3.0, 5 speed.
The story when she bought it was that a bolt had worked out of the motor mount, rubbing a hole in the oil pan. I put it on ramps and had a look-it turns out that a previous wrench owner had put the wrong pan on the engine, it had rubbed against the crossmember until it rubbed through and started a significant leak-obviously, the pan is going to need to be replaced.
So here's where I start the questions.
How do we avoid getting the wrong pan next time?
Is there any way to get it out short of pulling the engine? I have the mounts undone, the engine lifted as much as possible and the pan unbolted, it seems sooooooo close to coming out.....but doesn't quite want to clear the crossmember and the pick up tube. I did manage to get the oil pan out of a Aerostar with a 3.0 V6 with the engine in place, that wasn't easy but I did make it happen!
Alrighty then, back to the truck for some more wrenching wretardation.
