oil level sensor operation
fireguy12117
Livonia, Michigan
Did a quick search under the forum for oil level sensors, didn’t really get anything.
How’s does this thing work? I kind of busted mine up a bit when pulling the motor and wanted to try checking it before putting it back in. I was able to intermittently get conductivity through the 'case' and the single wire, but wasn’t exactly able to reliably duplicate this. I’m guessing there is a change in resistance measured by the pcm, but what actuates this? Is it a float? Actual contact? Anyhow, I’m going to jb weld around the connector that a broke and slap it in either way, and jump it out later if need be...
It's just a float-switch. The PCM doesn't know it exists.
They aren't very expensive from the dealer.
if its the same sensor as the one in my '87, you can't really bust up the sensor. mine is all metal on the outside. i broke the connector and thought the sensor was damaged too. $36 later from the dealer. i then needed the plug. the dealer wanted $26 for that. snagged one from a junk yard. all better.
i'll double check with my books that are in the freezing cold garage later, but, i assume its basically wired right to an idiot light on the dash?
if it does nothing for the pcm, then basically i just need it to fill a hole i guess.
EDIT: ok, i see what it does in the wiring diagrams...
