79F1504X400
I just discovered there is oil pooling at the base of the distributor. I cleaned it off, started the engine and watched with a mirror and flashlight as the oil slowly puddled around the hold down clamp. Could the o-ring around the distributor be bad or could it be coming from somewhere else?? I didn't think there would be enough oil pressure to push it back up from under the dizzy.
A couple days ago I did pull the distributor out enough to retard the rotor a tooth maybe the o-ring got damaged or maybe there isn't one there.....I didn't notice when I was messing with it cause I was going pretty much by feel.
